Will i be ok with just a pump?
Old Mar 19, 2007 | 12:06 PM
pHEnomIC's Avatar
Default Will i be ok with just a pump?
I got a cammed full boltons 02 ls1.
Next time i go home i am going to lean out my tune a bit and makea smoother transition of a/f on WOT so I am not sure what the IDC will be. These are stock 28 lb injectors.
I am now thinking about adding a wet nitrous kit 75-150, most likely going to spray 100. Now my question is that since wet kit supply additional fuel through the fuel port, will i be ok with just changing my fuel pump?
I am thinking a 255lph holley or racetronix.
Old Mar 19, 2007 | 11:12 PM
ZL1Killa's Avatar
you will prolly need injectors too. the only difference you are going to see with the pump is your fuel pressure from a normal 50 or so psi to 58-62psi with the pump. thats not going to net you a lot of room.
3x#ers or even 42#ers would do perfect, and even if you have more mods
i'm at 5psi and running 64% duty cycle.
Old Mar 20, 2007 | 12:04 AM
pHEnomIC's Avatar
Thing is, since it is a wet kit, it actually takes fuel from the test port out of that psi. So there is fuel from another source besides the injectors.
Old Mar 20, 2007 | 12:07 AM
DuronClocker's Avatar
You're right, if that's all you have planned, there is no need to upgrade injectors at this point. The fuel for a wet kit is supplied via the fuel solenoid from the schrader valve (make sure to remove the valve core or you'll effectively be running a dry shot and with stock injectors, that's asking for trouble!)
If you plan on making more power N/A though, larger injectors are a very good idea. As mentioned above, if you go that route, just go straight for 42#'s. Skip the 30# crap. I know I wish I would have..
Old Mar 20, 2007 | 12:17 AM
pHEnomIC's Avatar
Ok sounds good. In all honesty, once i get the setup, if injectors are needed according to duty cycle, i will go up to 42's. Just wanted to get an idea.
Btw, how do you remove the schrader valve core? Do you just use one of those tools for removing a tire fill valve?
Old Mar 20, 2007 | 09:47 AM
never2low's Avatar
yes use the tire valve core tool.
