Fuel Rail swap
Old Mar 21, 2007 | 08:45 PM
1BAD99TA's Avatar
Default Fuel Rail swap????????
How hard is and what all is needed to put on aftermarket fuel rails? I have a stock ls1 intake. My intake is off right now so I was considering doing a swap on the rails now instead of taking everything off again later. I do not know much about fuel systems so please forgive me. Also do the Speed Inc. rails with the plug n play kit come with all fittings?
Old Mar 22, 2007 | 09:47 AM
Nasty N8's Avatar
Not too difficult if you can remove the intake seccessfully you should have no problems with fuel rails. you wil need our rails ad install kit and it will have all you need to complete the install.
Nate
Old Mar 30, 2007 | 06:21 AM
Bandit LS1's Avatar
I called speedinc before I bought my fuel rails and install kit, the "plug and play" kit has everything you need to install them to your factory line.
Just some advice from personal experience.....I suggest you get the plastic fuel line dicconnect tool that slids over the line to dissconnect your fuel line from the factory rail.....I tried the cheap-o scissors deal for almost an hour with no luck.
