The Fuel Pump Access panel...
Old Mar 23, 2007 | 08:14 PM
Ar0ck's Avatar
Default The Fuel Pump Access panel...
Is the best thing ever to be thought of...
A few buddies & I had the entire assembly out in 2 hours. We had to make 1 trip to the hardware store for a Dremel bit, and then had some trouble getting the connections off the lines. Other then that it was a cake walk! Dyno numbers tomorrow!
Old Mar 23, 2007 | 11:00 PM
crazycat's Avatar
I just cut mine today also, after working on dropping the tank for a few hours I got pissed and bolted it back up.
I didnt pull the lines off yet it looks like its going to be a pain. any advice, its an lt1 also. thanks...
Old Mar 24, 2007 | 04:46 PM
Ar0ck's Avatar
Best advice is to get someone with small hands yet strong fingers to reach in and disconnect the 2 click style connections that are sorta under the panel still. I did a search here and found a few very good write ups but I can't find the exact one I used.
Old Mar 24, 2007 | 05:16 PM
crazycat's Avatar
O.K thanks. maybe I will have to lower the tank alittle so I can get my hands in there.
Old Mar 24, 2007 | 10:30 PM
JL ws-6's Avatar
Race your car!
I see alot of people do that... I did a racetronix kit on my car and dropped the tank, removing the catback was by far the worst part.... I just don't understand what the big deal is with dropping the tank out. With a 2nd set of hands to help with the filler neck, it's really not that big a deal.
Old Mar 24, 2007 | 11:21 PM
SSilverSSurfer's Avatar
trap door ftw,
Old Mar 26, 2007 | 10:21 AM
Country Boy's Avatar
Senior Member
I did it after dropping my tank about 5 times. I will never drop the tank again. Anyone that wont do it is CRAZY!!
Old Mar 26, 2007 | 11:26 AM
JL ws-6's Avatar
Race your car!
guess I'm a nut because I'm not hacking my car like that.
Old Mar 26, 2007 | 11:32 AM
kp's Avatar
kp
If you had a 98 you will feel different about dropping that tank lol. Lot of cars have have access holes from the factory to get the pumps out. If you do it nice and cover it up right I dont see the big deal, that metal is so thin there its not like its going to weaken the car by cutting a hole there. M6 cars have a huge hole where the shifter goes through and A4 cars dont
Old Mar 26, 2007 | 11:42 AM
JL ws-6's Avatar
Race your car!
I agree.. if you were to make a nice trap door out of alum with a frame and whatnot, that's one thing, but just cutting a fat hole there and leaving it... is hack.
Old Mar 26, 2007 | 12:06 PM
kp's Avatar
kp
I dont think anyone is just leaving the hole open when they are done, at least I wouldnt think so
I dont think 25 years from now someone is going to lift the carpet at a barret jackson auction and say 'wow this car isnt worth big money because someone cut an acess hole for a fuel pump'
But if you have a super mint stock car and the pump went out I would drop the tank most likely, but if you are upgrading to a walbro most likely you will have to pull it out a few times so the hole is a good choice IMO..
Old Mar 26, 2007 | 02:20 PM
MeentSS02's Avatar
Kleeborp the Moderator™
When it comes time for my fuel pump swap, I'll drop the tank the first time, but once it is out of the way, I'll cut a nice access panel while I'm in there, because I'm pretty sure I'll end up having to mess with something I screwed up...
Old Mar 26, 2007 | 04:34 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
Exactly the tack I took! I dropped the tank the 1st time to make sure it was flushed/cleaned. I then cut the trap door while the tank was out (easier) for future pump access.
-Jay-
Old Mar 26, 2007 | 07:13 PM
crazycat's Avatar
If you have a convertible plan on dropping the tank, or at least 5 or 6 inches down because the pump hits the rear window, no hatch to open.
Old Mar 26, 2007 | 09:26 PM
99zconv's Avatar
crazycat, are you saying that the pump will not pull up out of the tank in a convertible?
Old Mar 26, 2007 | 11:41 PM
CantKeepemhooked's Avatar
with a remote STS kit only 5psi-7psi would i have to get a new fuel pump? i hope not. if i do ill do the access panal for sure.
Old Mar 27, 2007 | 04:38 AM
JL ws-6's Avatar
Race your car!
yes you need a fuela pump with any type of boost period.
Old Mar 27, 2007 | 05:12 AM
Slowhawk's Avatar
LS1Tech Sponsor
Access hole is the best thing.98's take alot more cutting but 99+ it's very easy and very helpfull.We've had 2 cars that needed the pumps worked on numerous times.That hole paid for itself.
We always give the option though.Dropping the tank is an extra $200.Most people go with the hole and we make a nice plate to seal it up after.
Old Mar 27, 2007 | 05:15 AM
ss1129's Avatar
Kinda like crotchless panties.
Does anyone have a template or dementions on where to cut?
Old Mar 27, 2007 | 07:46 AM
if i get a new fuel pump and install it, would it run with stock PCM?
