Fuel pump retaining ring
Old Mar 31, 2007 | 04:27 PM
NHRATA01's Avatar
Default Fuel pump retaining ring
Search isn't working (of course, as I have the car apart in the garage).
Is there any trick to getting off that metal ring that holds the fuel bucket to the tank? I've spent about 2 hours whacking it with a chisel, punch, screwdriver, extension, about anything I could find. Soaked it in PB Blaster, and even knocked it back clockwise to see if it would loosen up at all. I can't get the F'n thing off! It'll budge about 1/4", and won't go any further.
Any advice?
Old Mar 31, 2007 | 05:39 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
I had the exact same problem 1st time removing - after that it will go on & off easier.
If you have got it knocked around a little bit - you will notice that a small space has opened up between the slot in the ring and the tab on each tab. I used a screwdriver with small blade, inserted it into this space, and pried the ring against the tab to remove the ring a little at a time - going around to each tab in turn.
Hope this make sense...
-Jay-
Old Mar 31, 2007 | 07:29 PM
98Camarod's Avatar
I dont know if it is the same ring as in a van, but we changed a fuel pump out the other day in a Savannah. There were two holes in the ring and my uncle had a tool that squeezed it and it popped right up. I don't know if this helps
Old Apr 1, 2007 | 03:47 PM
NHRATA01's Avatar
-Jay-
Good advice! I went at it again today and tried prying at each tab opening, and it worked.
Also, leg pressing the gas tank back in place while trying to start the bolt in the holes for the straps (and having the threaded inserts in the frame constantly move around) is not fun for anyone.
Old Apr 2, 2007 | 03:04 AM
1QUIKWS6's Avatar
Glad you could make heads or tails out of my description
I actually had my wife under the car helping with the tank re-install - suprisingly enough, it worked out fine...
