How to assemble teflon hoses?
Old Apr 5, 2007 | 01:40 PM
Stick only's Avatar
Default How to assemble teflon hoses?
Anyone know where I can find a 'how to' on this for reusable teflon fittings?
Old Apr 5, 2007 | 03:13 PM
ss1's Avatar
ss1
I think it depends on the brand and type of hose. Some of them (Icore, maybe?) require an "olive" while others may not.
Old Apr 6, 2007 | 07:26 AM
Stick only's Avatar
OK, the fittings have a ferrule inside, it looks to me like you would push the hose through the nut, slide the ferrule onto the teflon portion of the hose, which would flare out the braided stainless. At this point you would tighten down the nut to lock the ferrule and stainless braids inside the nut???
Old Apr 6, 2007 | 05:50 PM
andereck's Avatar
You got it Mike. Teflon hose is the easiest to put together.
I cut the hose, you must be sure its done square, slide on the nut and then take a small screwdriver and pry the sleeve gently away from the teflon liner. Deburr the edge of your cut lightly with a pocket knife if necessary, push on the ferrule until the cut end butts up against the step of the ferrule, I use a wall or bench to push against. Insert the tube fitting while pushing and twisting slightly, you want to make sure you don't catch the edge of the tube liner and fold it. Tighten the two together, teflon is nice because you don't have to fight it or use a vise to tighten.
If you get stuck I can take pictures of an assembly. Let me know.
Mark
(if you wonder why I'm being so nice its because I'll need you when its time to figure out my clutch adjustment on my Ram sintered iron single... )
Old Apr 7, 2007 | 06:30 AM
Stick only's Avatar
Great info. I was surprised nobody had asked this before on here.
No prob on the tuning of the clutch just let me know what you need!
Old Apr 7, 2007 | 06:32 AM
Stick only's Avatar
Mark - I just got an email from Jared at Aeromotive, his 98 with the same procharger setup otherwise stock made 487/445 so I'm pumped for tuning on mine!
Old Apr 7, 2007 | 07:08 AM
andereck's Avatar
Those cars are just plain stupid with a blower. I hear about C5's all the time with over 600 and I just can't see how they use it. Almost 500 with a completely stock car is going to be a blast to drive. You've got complete exhaust so you should see over 500, let me know if you want another pulley.
