help on fuel line routing
Old Apr 11, 2007 | 12:06 AM
camaromotorsports's Avatar
Default help on fuel line routing
i have instaled a ls1 int a 68 camaro, i have puchased a rock valley tank with pump in tank, i am usinga professional products ls1 intake with billet fuel rails, my plans are to run the 3/8 fuel line into the feed side, and i have a return line as well, how do i need to go off the other rail, into a regulator , or what, there has to be something there or the pressure will just go straight through back to the tank, could i come out of the return rail into a regulator on the in port, and out of it to the rturn line on the out port and work fine, and just plug off the evap fitting, all help or info is greatly appreciated
