Does anyone have a write up for this?
Old Jun 4, 2007 | 11:24 AM
rufretic's Avatar
Originally Posted by ChevyChad
Here is how I did mine.
That's how I did mine except my feed comes from under the tank with two inline pumps that Y together before the T fitting. One pump is activated by the hobs switch. It seems to work great.
Old Jun 4, 2007 | 11:50 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Originally Posted by No Juice
What is 3/8" relative to -6, -8 ?
3/8 is a -6
Old Jul 6, 2007 | 05:30 PM
3fingas's Avatar
Cant tap, must braaaaaaze or weld them or buy a 97 vette rail. have fun findin them.
Old Jan 11, 2010 | 02:56 PM
chevyz2801's Avatar
good info
Old Jan 18, 2010 | 08:41 PM
pdasterly's Avatar
Old Sep 8, 2012 | 04:33 PM
JoshuaGrooms83's Avatar
diggin this up since im looking it upand alot of people are asking alot about them too. I particularly like the routing diagrams. thanks guys. i take it, without modifying the stock rails, aftermarket rails are pretty much a must to get this to work huh?
Old Sep 8, 2012 | 05:45 PM
Originally Posted by pdasterly
and what exactly is that?
Old Apr 7, 2014 | 09:29 AM
5.slow99's Avatar
sorry for bringing up a dead thread but i was wondering if this is still the way everyone is doing a return or if there is a better way, and what is he referring to when he says evap to ATM???? thanks in advance
Old May 30, 2014 | 05:29 PM
MillsMotorvation's Avatar
Adding a boost referenced FP reg to a 2004 GTO, is the fuel system the same, and where is the stock fuel filter located? Great info here!
Old Jun 9, 2014 | 11:55 AM
Majestic9C1's Avatar
So you are using the stock EVAP line as a return line and getting rid of the EVAP solenoid on the intake manifold?
Old Jun 17, 2014 | 09:26 PM
if that's what works, I don't even see how these lines run, look to go into the trunk floor!
Old Nov 27, 2014 | 12:47 PM
  #32
Firehawk896's Avatar
So my question is did you take the stock FPR out of the pump housing and put it up by the Fuel Rail?
Old Dec 12, 2014 | 04:12 PM
  #33
JRENIGAR's Avatar
I was told by a reputable fuel system builder yesterday that the stock evap line is not adequate for a return line. They said it is only designed for vapors and not liquids. I was told to run a 6an line back for a return and keep the evap system working like stock. Anyone care to comment on this? I would also like to know about the factory regulator removla. Does it get left off for a free flowing return inlet? I know the factory regulator dosent go back on the fuel rail though.
Old Apr 11, 2015 | 09:01 PM
  #34
Dragframe's Avatar
Joining in on this thread resurrection..
The 'reputable fuel system builder' doesn't make money off you using your evap line as a return. It works just fine. Many have done it. I just saved the headache and bought a line kit from Nasty.
You install a FPR up front. Run your feed directly to the fuel rails. Your return comes off the fuel rails into your regulator, and you return comes off the regulator back to the tank. This isn't the only way to skin this cat though (but it is the best way)
