Injector help?
Old Apr 28, 2007 | 09:25 PM
2manytoys's Avatar
Default Injector help?
So, correct me if i'm wrong. Stock injectors will support a mild H/C package. I have searched a little. Is this correct? I will know more about injectors and duty cycle when i get my tuning software. Thanks for any help.
Old Apr 29, 2007 | 12:20 PM
deadmanTA's Avatar
When you get your tuning software check the duty cycle, if it goes over 80% then upgrade, if it doesn't then I would't worry about it. The 98's had a slightly larger injector also, 28 lbs where the 99-02 have 26 lbs.
