Racetronix single pump kit (relay)
Old May 2, 2007 | 06:38 AM
deejaydaze's Avatar
Default :::: Racetronix single pump kit (relay) NEED HELP!!! :::::
Does anyone have a part number for this?
Local auto store and match?
::EDIT::
(Just bought one from Thunder)
By jumping the positive off the alternator and into the positive to the pump....I get 0.00v
I reconnected factory/stock plugs and now my pump works.
Old May 2, 2007 | 10:41 AM
deejaydaze's Avatar
::::UPDATE:::
I've got power past the point of the relay!
Actually all the way to the plug that connects into the top of the bucket!
How am I getting power to both factory and Racetronix plug, but the pump only works when the factory plug is connected!!!!!!
Old May 2, 2007 | 06:46 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
Could be bad ground connection on Racetronix harness. I mounted both my relay and upgraded wiring harness ground behind the bolt that holds the brake line bracket to car directly behind fuel tank on DS.
First I made sure to grind off paint around bolt hole, grind both sides of bracket, and cleaned up underneath of attaching bolt prior to installing.
Old May 2, 2007 | 09:33 PM
deejaydaze's Avatar
Thanks for the reply man. I don't know how else to test for a good ground.
Old May 4, 2007 | 06:48 AM
deejaydaze's Avatar
Ok so yesterday the only thing I did was replace the GM positive cable with a brand new GM positive cable. Car is running just not charging the battery. Well nothing over 12.9 volts!!
Regulator?
