injector ?
lbs/hr=(BHP X BSFC)/(No of inj X DC)
BHP=Peak Horse Power
BSFC=Brake Specific Fuel Cosumption
DC=Duty Cycle
So, (650 X .50)/(8 X .85)=47.79lbs/hr. I've been told to use .50 for the BSFC of engines with power adders such as blowers/turbos/dry nitrous systems. No power adders use .45 BSFC. If you used a .55 BSFC you'd come up with 52.57lbs/hr. The .85 is for 85% injector duty cycle. Hope this helps.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, the 650 is your estimated 500 + 150 wet shot. I don't understand what you mean by accounting for fuel pressure. I'm assuming you'd be running the LS1 58 psi. Rated injectors can/will flow more with more pressure but once you've set your fuel pressure via a regulator it should stay right on (with a good aftermarket unit anyway). Hence the SVO injectors pushing more fuel in LS1's as they are rated at 43.5lb/hr and the LS1 injectors being rated say 28.6 ('98?) at 58psi. Or is that is what you are asking? If you have a rated flow of 43.5 psi and a 30# inj you get 30lb/hr. Up the pressure to 50 psi and you get 32.16lb/hr. Up the pressure again to 60psi and you get 35.23lb/hr out of the same injector. A 55lb/hr at rated flow (of 43.5 psi) goes to 58.39 at 50psi and 64.39 at 60psi. As long as your buying injectors advertised for an LS1 they should be rated at 58psi. For most (but not everything) else they will be 43.5 psi rated flow. I went ahead and did the math-43lb/hr injectors would flow 50lb/hr at 58 psi. 50lb/hr injectors would flow 57lb/hr at 58 psi. So some injectors in the 43-45lb/hr range should be good.
It's late and I might not be comprehending what you are asking. If not I'll give it another shot. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ February 20, 2003, 03:05 AM: Message edited by: 68LSS1 ]</small>
for new 42's for $300, pm me
(600 x .50)/(8 x .85)=44.11lb/hr
now lets look at those 42svo's, to figure the flow at 55psi you need to take the (square root of 55/43.5) x 42 = 47.22actual flow at 55psi.
being very conservative it looks like the 42's would be ideal
<small>[ February 23, 2003, 03:19 PM: Message edited by: parish8 ]</small>
I'm in pretty much the same boat as rich is. I've got a MTI 422 that I'm looking to run a dual stage NX MAF kit on in the spring with a 100hp/75hp set. I've dropped in the WS-340 intank pump and the SVO 42s look like the right package. I shot you a PM to get the contact info for the shop.
Thanks,
Rick
