AN fittings and hose install?
Old Mar 10, 2003 | 11:28 AM
66ImpalaLT1's Avatar
Default AN fittings and hose install?
This isnt for my LS1, but I'm running a new fuel system on my LT1. I bought all Aeroquip AQP Socketless hose and fittings. I know for the hose ends you just lubricate them and push them on, but what about where the AN fits together, like at the rail and fuel filter?
Do you need any type of sealant on there?
Thanks,
Eric
Old Mar 10, 2003 | 02:14 PM
Default Re: AN fittings and hose install?
Thanks Ryan, I know you dont need to seal the threads, but I wasnt sure why they sell O-Rings for them.
My fuel pump assembly uses NPT, so I'll tape those adapters.
Eric
Old Mar 10, 2003 | 05:41 PM
trackbird's Avatar
I believe the O-rings are for the angled hose ends that will rotate in relation to the hose. They are not to seal the actual connection point.
Old Mar 10, 2003 | 09:38 PM
Ryan K's Avatar
Pathological Modifier
Trackbird,
The o-rings are for AN fittings that do not utilize the angle section to provide the seal, ie. flush mounting the fitting and the component.
Several companies (like Areomotive) use AN for thier pump, regulator, and fuel filters. They don't have the internal sealing ring, so they use an o-ring.
As far as angle fittings go, they still have the angular sealing surface, (once tightened, they no longer swivel).
Ryan K.
Old Mar 10, 2003 | 10:17 PM
trackbird's Avatar
I forgot about those. I was thinking "replacement parts". Guess I'm slipping...I forgot about the fuel pump/regulator fittings that use O rings. Thanks for catching my error.
Old Mar 11, 2003 | 12:03 AM
red ws6 99's Avatar
The AN fittings do not need sealant. The sealing surface is the 37 deg flate not the threads as in pipe.
Gary
Old Mar 11, 2003 | 12:13 AM
Ryan K's Avatar
Any fitting that is AN will not need sealant. However if you have any fittings that are NPT (pipe), then you need to use teflon tape/paste. Also, any fitting that is AN that goes into a fuel pump or whatever, that dosen't internally have the 37deg. angle face will need an O-RING.
Aeromotive A1000 fuel pump is one example of where you would need an o-ring.
Ryan Karasek
<small>[ March 10, 2003, 12:17 PM: Message edited by: Ryan Karasek ]</small>
