Question about Injector Offset Table in LS1-Edit
Old Mar 25, 2003 | 08:20 AM
Black LS1 T/A's Avatar
Moderator
Default Question about Injector Offset Table in LS1-Edit
Injector Offset table changes is an area I need to explore.
I bought the new Seimens Deka Hi-Z 55# injectors and, though I observe more fuel delivery, I had to lower Inj Flow Rate values below calculated values for the Injector Size, Test Pressure and Rail Fuel Pressure in order to achieve zero LTFT's at WOT and below zero during cruise and part throttle.
After tuning for non-positive values, it ranges from about -1.6 to -14.0 depending on idle, low throttle cruise or modest %TPA.
I get about -1.6 to 0.0 at around 15% or more throttle.
It varies about -14.5 to -4.5 or so at around 0.6 to, say, 10 %TPA.
At idle, it drifts upward until it reaches about -1.6.
When I tuned it with calculations closer to actual size/tested PSI/Rail FP, this wide range of values just made me bump Inj Flow Rates down further and further keep LTFT's from going positive.
The question:
Is there any intelligent way to go about calculating and adjusting Inj Offset for injectors that are othjer than stock?
I think I understand someone has such an animal for SVO 42's. But, what about a set of injectors like mine?
Could it possibly be better to use such a table as used for the 42's as being at least better than the stock Injector Offset and go from there as an example?
Thanks
Old Mar 26, 2003 | 12:45 AM
SS00Blue's Avatar
Default Re: Question about Injector Offset Table in LS1-Edit
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black LS1 T/A:
<strong>The question:
Could it possibly be better to use such a table as used for the 42's as being at least better than the stock Injector Offset and go from there as an example?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe I may have a spreadsheet for your application. When I get home I'll check, and if I have what you need, I'll forward it to you.
SC-
Old Mar 26, 2003 | 12:55 AM
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SS00Blue:I believe I may have a spreadsheet for your application. When I get home I'll check, and if I have what you need, I'll forward it to you.
SC- [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool!
michael@mlbuie.com
Thanks!
Old Mar 26, 2003 | 05:45 AM
SS00Blue's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SS00Blue:I believe I may have a spreadsheet for your application. When I get home I'll check, and if I have what you need, I'll forward it to you.
SC- </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool!
michael@mlbuie.com
Thanks! [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mike,
My Windows ME took a dump last week and I'm having trouble finding that worksheet. I'm about 90% sure it's the one you want. I'm going to keep looking.
SC-
Old Mar 26, 2003 | 05:49 PM
Moderator
Thanks! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'll keep an eye out for it.
Old Mar 31, 2003 | 05:49 PM
nevrenuf's Avatar
I'd love a copy of that too!
tomc5@bellsouth.net
Old Apr 2, 2003 | 08:24 AM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nevrenuf:
<strong> I'd love a copy of that too!
tomc5@bellsouth.net </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So would I. Sorry fellas, I've looked everywhere. I just can't find it.
<img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
SC-
Old Apr 2, 2003 | 09:46 AM
Moderator
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nevrenuf:
SC- </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" />
Thanks for checking, though. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Apr 4, 2003 | 08:56 PM
Ragtop 99's Avatar
tomc5@bellsouth.net
michael@mlbuie.com
I assume you are looking for Chris B's injector offset.XLS model. It's in your inbox. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
You guys can ship it to others that ask for it.
Old Apr 5, 2003 | 05:06 AM
Moderator
Thank you very much. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'm not sure if I will or even should use it, but I want to try to understand it.
I've been told by a tuner not to do it unless it is verifiable that the injector I use needs that specific offset, or I risk damaging the injectors
over time and even worsening the tune. I can see how that is true without him telling me that.
But, I want to see how it works.
Thanks, again!
Old Apr 6, 2003 | 10:19 AM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>I assume you are looking for Chris B's injector offset.XLS model. It's in your inbox. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's the one! I know'd it was somewhere out thar...
SC-
Old Apr 9, 2003 | 06:05 PM
Phate's Avatar
Can I get a copy of this?
scott.allen@earthlink.net
Thanks,
Scott
Old Apr 9, 2003 | 08:44 PM
parish8's Avatar
single digit dreamer
can i get a copy too, i would like to see it.
cobra99vert@aol.com
thanks
Old Apr 9, 2003 | 10:52 PM
JNorris's Avatar
Moderator
Please send me a copy as well.
Thanks
John
jnorris404@aol.com
Old Apr 10, 2003 | 10:11 AM
RedHawkWS6's Avatar
another one for a copy
hawkinke@soc.mil
Old Apr 10, 2003 | 05:36 PM
red ws6 99's Avatar
you can get the file from http://ls1edit.slowcar.net/
But it does you no good unless you have the ford or whatever company made the injectors offset file. Even then it won't be exact
Gary
