Fuel Pump for a 427 LS1
Old Mar 29, 2003 | 06:03 PM
FastBlackTA's Avatar
Default Fuel Pump for a 427 LS1
What are most big cube ls1's using as a fuel pump if a simple wet/dry nitrous system is installed? My rotating assembly and machined block should be in sometime soon, and once i assemble/install it i will be retaining my current NX wet kit until i step up to a dp fogger.
I'm not going to wait around for the 99+ racetronix setup, and i'd rather do an in tank pump if at all possible without seriously moddifying my tank.
If an external pump is on order, do i absolutely have to run it inline with the stock pump or can i get rid of the stock pump and modify the pickup accordingly??
Thanks in advance,
Conrad <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
