F/P?? How common???????
Old Apr 14, 2003 | 09:22 PM
01Z0H6's Avatar
Default F/P?? How common???????
My fuel pump is going out will replace with a Granatelli FP.
My question is, i see many post's of guy's FP's going out!
Typical? How many miles do you guy's have on the stockers? Or, are you simply replacing for racing?
thanks in advance. BTW, my car has 91K! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Matt.
<small>[ April 14, 2003, 09:24 PM: Message edited by: PewterY2KZ28 ]</small>
Old Apr 14, 2003 | 09:58 PM
Chris99WS6PWTMET's Avatar
Default Re: F/P?? How common???????
My 99 started getting weaker at around 40K at 3.5 years old. FP was good at idle and cruise, it just dropped off badly at WOT. I installed a Walbro 340 pump and all is well now.
Old Apr 15, 2003 | 06:49 AM
JNorris's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris99WS6PWTMET:
<strong> My 99 started getting weaker at around 40K at 3.5 years old. FP was good at idle and cruise, it just dropped off badly at WOT. I installed a Walbro 340 pump and all is well now. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How much (psi) is "dropped off badly at WOT"
John
Old Apr 15, 2003 | 03:12 PM
01Z0H6's Avatar
Chris, what EXACTLY were your symptoms when your pump was going out?
My car takes a little longer to crank @ times.?
Cooler days are fine. However, when it warms up outside is when i crank the car 3 or 4 seconds before it starts.
Like you, idle is fine & the car runs great.
Also, had a FP guage on it. Car showed 56psi. went to lunch approx 1hr & the fuel pressure had dropped....... If this helps.
<small>[ April 15, 2003, 03:24 PM: Message edited by: PewterY2KZ28 ]</small>
