Question about PE and flow rate???
Should I change any settings in Edit to add fuel since I am running to where it's adding fuel, to be stoich?
Is the injector flow rate table what get's changed?
Pulse rate?
Is changing the PE to 65% instead of 90% going to cause me to go lean?
I have ordered some 42 Lb RC injectors for it, but I don't wanna blow it up till they get here.
I already have a tune # for the larger injectors(flow rate table changed)
Thanks for any help!
Sam- 2000 5.3 truck intercooled ATI P-1SC
<small>[ April 24, 2003, 08:57 PM: Message edited by: samuriarte ]</small>
Gary
I can't even get on a dyno for over a week, so I am going to do some Atap logs, and see where I am at now. I put the new injectors in today.
They are SDM 370's from RC Engineering. I think they are rated at 42 lbs w/ 50-60 psi fuel pressure. It is acting like it's rich, surging a little.
I also took off my FMU that ATI provided that boosts the fuel pressure since I have the bigger injectors on. I hope it's ok till I get it on the wideband here. I think there is only one in town, and they are swamped already. Thanks, and I will check back with some Ltrims in a while. Sam
