Looking for quick connect fuel line fitting
Old May 10, 2007 | 11:24 AM
longboard's Avatar
Default Looking for quick connect fuel line fitting
Howdy, I'm in need of a qucik connect fuel line hose/fitting that plugs into the corvette fuel filter/regulator that will also connect to an AN fitting. I used braided stainless fuel lines on my 61 Impala to my LS1 and after market fuel tank with the corvette fuel filter/regualtor. But I need to connect the fuel line to the filter/reg and it has a quick fit on one end. The other end has AN fitting which ar fine. Where do you buy quick connect fuel line fittings?
Old May 10, 2007 | 11:30 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Jegs and Summit have tons of them. Summit has a better search function tho, so I always look it up on summit and once I get the part# I check Jeggs too for price and availability.
Old Jul 14, 2007 | 02:57 PM
67rsss's Avatar
Longboard, stumbled accross a few of your threads doing a little X-frame research. We are considering a swap into a 61 LeSabre X-frame. How did your project go? Our Camaro was almost painless, but the Buick looks a bit more complicated. Where are some good pictures of your project, and what issues did the X-frame give you????
