Car pops and stumbles after injector upgrade
Old Apr 27, 2003 | 08:11 PM
CB99SS's Avatar
Default Car pops and stumbles after injector upgrade
What would cause my car to pop and stumble after I installed my 30 lb SVO injectors? I also installed a walbro 255 fuel pump. It does it when I'm taking off from a light or stop sign. It doesn't do it all the time. Last night when leaving a local hangout. I got on the car pretty hard. Friends of mine said my car was poping then when I hit second gear it stopped.
I've changed my injector flow rate table using ls1 edit. How do you check injectors? Could my problem be from a injector putting excess fuel in the cylcinder? Could it be a bad spark plug or wire?
Thanks for the help.
Old Apr 28, 2003 | 08:21 PM
96SCTA's Avatar
Default Re: Car pops and stumbles after injector upgrade
what does your fuel preshure look like????
Old Apr 28, 2003 | 09:56 PM
CB99SS's Avatar
It shows 64 psi. Then when I floor it it drop to 58 psi.
Thanks
Old Apr 30, 2003 | 05:27 PM
Predator's Avatar
Why don't you try scanning the car dude; even a mechanic would want to see data before making a diagnosis .
