need some advice please :(
Old May 23, 2007 | 02:49 PM
turbols1chick's Avatar
Default need some advice please :(
so this morning i get in my car to go to work and it starts and then instantly dies. it does this about 3 times and then i finnaly get it to stay on by pushing the throttle a little to get my rpms up. i let of its idleing around 500 and wanting to die then idles normal for about 30 sec so i try to pull out and it dies. i talked to a friend that is a service writer at chevy and he said it would be the fuel pump and i talked to friend at my work ( an audi dealership) who races ls1's and he said mass air flow. so i guess i kinda need some advice or if anyone has had a problem like this that can kinda help me out. i have a 2002 ws6 with a lid,lt'swith an off road y, and an electric cut out. if that means anything to my issue thanks for helping- jessica
Old May 27, 2007 | 07:54 PM
ri5e's Avatar
Attach a fuel pressure gauge at the schrader valve and check to see if you are getting 58 PSI of fuel pressure. If your fuel pressure is too low, you may have a bad fuel pump or the fuel hose in the tank is leaking.
