Need to drain tank....how?
I wanted to siphon the gas out of my tank so I can put some fresh gas in (been in winter storage)
I get the tube down only so far and I hit something, a baffle or something
anybody have any tips on how I can get this old gas out?
You may be able to create a siphon from the fuel line that connects to the filter but I'm not sure how easy that'll be.
The 3rd gen days were easy when there was just an overflow vent. We just pressurized the tank with air and it pumped the gas right out of the fuel line. Doesn't work on 4th gens (at least ls1) I'm guessing because that rollover flap.
I know when I key on, the pump primes...but I'm sure if I started the car with that line open, I'd run lean in a second?
Do you know how much fuel is in the tank?
You could go under the car and disconnect it from the fuel filter, put a hose on it. Energize the pump and drain the tank.
