Fuel Pump or Not?
Old Jun 30, 2007 | 08:45 AM
ApacheDrill's Avatar
Default Fuel Pump or Not?
Okay i was coming off the track and hit a dip on the return road.. the car bottomed out just a little in the front and the engine died.. when i turned the key forward the fuel pump was not kicking on and obviously no fuel pressure on the rails.. Before i order a fuel pump and drop the tank, is there something i should check just to make sure its the pump? Seems like a no brainer, just want a second opinion..
Old Jul 1, 2007 | 12:12 AM
WS6RACING's Avatar
I bump may have disconnected a ground or power wire to your pump. Start there. Good Luck.
and if it comes to it my friend had a small door cut out of his trunk that went right to his fuel pump so that he didn't have to chop off the exhuast. Thats a super duper idea.
