ok i need your help...
Old Jul 5, 2007 | 07:35 PM
ls2 bait's Avatar
Default ok i need your help...
im looking at this thing and its getting on my nerves. i need to install a fuel pressure sending unit (rather large stewart warner unit) and a fuel pressure safety switch on my car. buuuut the stock rails only have the one port on them. and of course it looks to be an odd size thread. so does anyone make a kit for this or point me in the direction i need to be looking to get this to fit. id also like to keep it all under my frc's if possible. from what im thinking ill need a 180* elbow and a t fitting off that so as to install one on each side of the t. im hoping someone makes one because id rather not peice it together.
Old Jul 6, 2007 | 10:13 PM
ls2 bait's Avatar
t.t.t.
Old Jul 7, 2007 | 12:53 AM
SSDriver's Avatar
the tread on the end of the fuel rail is a -4 AN fitting. Fittings are all over the place in -4. You can use this fitting it has dual 1/8" ports.
http://www.nitrousoutlet.com/catalog...roduct_id=2697 -notrous outlet(sponser)
if you need to you can also buy a -4 female x -4 male 90 or 180, not sure exatly what you need to make it fit under the FRC( I don't have any).
Your going to need a -4 cap(not the plastic one that is on your stock rails). You need an actual -4 AN cap.
also DO NOT FORGET to remeove the schrader valve inside the end of the stock fuel rail(just like your tire fill valves have). You can buy a schrader valve removal tool at any auto store in the tire section for about a dollar. if you don't remove the valve your fuel pressure safety switch and sending unit wont work because they will have no fuel/pressure going to them.
-William
