60lb or 80lb
Old Jul 6, 2007 | 06:18 PM
Mixing32's Avatar
Default 60lb or 80lb
Which one will I need to handle 800rwhp? Also will a 450 bosch support those injectors?
Old Jul 6, 2007 | 09:24 PM
Armageddon's Avatar
...with cheese.
60's will not support 800 to the tire on pump gas without running a ridiculous p/w. I know for a fact it's possible with a fuel that supports a higher resistance to detonation but not dinosour ****.
Old Jul 6, 2007 | 09:56 PM
98turbls1's Avatar
also think about if you want a converter box or not... If you're on the stock pcm and don't want a converter box then 60's are what you have to work with... You also think about some meth..
also, what size engine is this on?? If it's on a 346 you're going to have to push the **** out of it but if it's on a larger engine you can make more power on pump gas...
Old Jul 6, 2007 | 11:15 PM
DeltaT's Avatar
You can get nice, plug n' play (no box needed) 72# ones from RC Engineering. I'm using them and they will get you well into the 800's.
Jim
Old Jul 7, 2007 | 12:27 PM
Mixing32's Avatar
Its going to be a 383 stroker with 8:1
Old Jul 7, 2007 | 07:05 PM
Earl H's Avatar
60lb mototrons have supported 800+rwhp in a number of Vette applications. At 85psi f/p, the are equivalent to 80lb or so injectors...
Old Jul 8, 2007 | 10:35 AM
Mixing32's Avatar
What fuel pump can do that?
Old Jul 8, 2007 | 12:11 PM
Mr.MartyStone's Avatar
I think the bosch 044 pump only flows enough to about 680 flywheel hp. Maybe with a voltage converter or BAP at 18 VDC then possibly it could get you to 800 flywheel if you're lucky. Dual pumps for the win in your situation.
Marty
Old Jul 10, 2007 | 05:34 AM
2MuchRiceMakesMeSick's Avatar
Most external pumps can. Im going to do it with a magnafuel
Old Jul 10, 2007 | 10:35 AM
Nasty N8's Avatar
MagnaFuel or twin Walbro's
Nate
