what injectors..
Old Jul 19, 2007 | 09:19 AM
edwardswb's Avatar
Default what injectors..
I have a completely stock fuel system right now. I'm full bolt ons, cam (TRex), about to install an NX wet kit, 150 shot. I'm going with the racetronix pump kit. (fuel pump and harness) 42 pounders or is that overkill?
Old Jul 19, 2007 | 09:26 AM
brad8266's Avatar
run the 42's
Old Jul 19, 2007 | 10:58 AM
Nasty N8's Avatar
A little over kill for the current mods but if you are planning more in the future they will not hurt. The Nitrous is not taxing the injectors.
Nate
Old Jul 19, 2007 | 10:28 PM
edwardswb's Avatar
N8, I don't see stock injectors handling this, what would you recommend? I'm already planning another build so I'm keeping this one on a tight budget. My goal is high 10 cam only, mid-bottom 10s on the juice. I won't be able to re-use 42lb injectors on the next build..muchless anything else.
