Fuel Pump Problem?
Old Aug 24, 2007 | 08:13 PM
seawolf18's Avatar
Default Fuel Pump Problem?
When I took off from a stop sign today, my car acted like it wanted to die. When I stepped on the gas it did not increase the engine speed, car just sat there sputtering. This happened for about 3 or 4 seconds, then all of a sudden it took off like a a scalded ape. talking to some guys around here that know about cars, they say it could be the fuel pump going out? I have 30lb SVO's and still have the stock pump. car has 75K miles on it. Any suggestions on what it could be or what to check? Thanks.
Old Aug 25, 2007 | 09:20 PM
roadhog_113's Avatar
i am in the middle of the same problem. so far i changed filter and regulator still does it but i think the regulator helped a bit. check fuel pressure and vaccuum. if pressure sux then you can always fab up a shut off valve before the rails to determine if the pump is building pressure or if the regulator is not closing. good luck.
Old Aug 25, 2007 | 11:25 PM
Camaroz's Avatar
My 98 does this on a rare occasion. It does it usually between 1200-1600rpms when it happens then it's fine. There's really nothing that makes it do this either.. it's always totally random
