Alternatives to Braided stainless?
Old Aug 27, 2007 | 02:03 PM
striker754's Avatar
Default Alternatives to Braided stainless?
Braided stainless is so expensive as we all know, as are the fittings. Are there any good alternatives that are cheaper and nhra legal? I know hard line, but is there anything that is flexible as well?
I also hear you get a bad gas smell through the braided stainless.
Old Aug 27, 2007 | 03:49 PM
Nasty N8's Avatar
We use pushloc style hose that is black and alot cheaper than SS
Nate
Old Aug 27, 2007 | 04:02 PM
Disturbed Bird's Avatar
how about coated ss lines you wont get smells through that.
Old Aug 27, 2007 | 04:07 PM
striker754's Avatar
im thinking about using hardline for the majority of it and then ss near the engine and the fuel tank.
nasty I sent you a pm, where do you get the pushloc stuff?
Old Aug 27, 2007 | 05:02 PM
Lason's Avatar
Pushlok stuff here too. I love the stuff!
I plannaed on running hardline through most of my build till I read that the hardline is a little smaller ID than the flexible lines. Not a huge deal by any means but it made me think and Im just using black aeroquip socketless.
One other thing though, I have heard people complain of gas smell with all braided lines.
Old Aug 27, 2007 | 06:13 PM
striker754's Avatar
is aluminum hard line fine? i just plan on using it along the frame rail in my rx7. I will use braided from the engine to the frame rail and from the frame to the fuel pump
striker754's Avatar
also is the aeroquip socketless line nhra legal? i know nhra frowns on rubber lines
Old Aug 27, 2007 | 06:37 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Good Question..... Curios to find out.
Old Aug 27, 2007 | 10:48 PM
striker754's Avatar
hmm fully braided costs about the same as hard line/braided. teflon lined stuff is only 71 dollars more for return and feed line. ill probably get teflon so no smell
Old Aug 27, 2007 | 11:15 PM
striker754's Avatar
I got an email notification that someone posted that teflon lined hoses need crimped on connectors?
Old Aug 27, 2007 | 11:36 PM
rosey's Avatar
If your going with -8AN(1/2") or smaller, you can hit up www.harrisspeedworks.com They are a sponsor that mostly deals with nitrous stuff, but they will put together custom length -3, -4, -6, and -8 lines. I'm pretty sure they are teflon lined, it says on the site they are rated for fuel, and the nitrous lines that they made for me appear to be teflon. You can also get the lines with a pvc coating on the outside, so they are smooth to the touch and won't tear apart anything they rub on.
Right now I'm running the stock 5/16" hardlines in my rx7 with regular -6 braided lines for connections at the engine. Haven't had any fueling problems yet, but I plan to get an aftermarket FPR and mount it in the back and just run a single -8 hardline under the car. I might use a few unions so the line can come apart at a few places, and make it easier to bend/run, but I don't plan on using many SS braided sections if I can avoid it.
Hard line with tube nuts and sleeves are pretty cheap, and a 37* flare tool isn't too expensive either. I was thinking about getting the $30 tool from summit...seeing as making single flares in aluminum tubing shouldn't take much.
If you do this anytime soon, feel free to snap some pics and post them here or on the v8rx7 fourms...I probably won't be doing mine until I address some other things on my car, and I'd be curious to see a similar setup before I go ahead with it.
Old Aug 27, 2007 | 11:52 PM
striker754's Avatar
stock rx7 lines wont support a t76 i dont think
harris seems to have good prices for just the hose. i'll have to call them tomorrow.
Old Aug 28, 2007 | 11:44 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Any info on the pushloc hose being legal?
Old Aug 28, 2007 | 04:24 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Just got off the phone with NHRA tech dept. Pushloc hose is legal.
Old Aug 28, 2007 | 09:52 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I posted/deleted concerning teflon lines last night because I misread the post. True Teflon lines similar to brake & nitrous lines require crimp on connectors in the larger sizes. This can be a pain because you have to install & trim the hoses to fit, align the fittings, then remove & take the hose to have ends crimped on. Also most of these fittings are zinc plated steel because they are generally used for very high pressures. The nice looking anodized aluminum fittings are often not available for this application.
Teflon lined hoses on the other hand, as mentioned in an above post, do not necessarily have to be crimp type because they are essentially the braided rubber hose with an internal teflon liner.
