Fuel Rails in Sequence or Parallel
Trying to decide if there is any advantage in running a y-block into both rails off my feed line, then running from each rail to the regulator. My old setup went into one rail, then the other.
Setup is as follows:
Magnafuel 4302, -8 feed line, Rails that came with Vic Jr, magnafuel regulator.
I already purchased the -8 to dual -8 yblock but it would be a much cleaner install if i could go into one rail then the other with the regulator hanging off the end of the second rail.
Nate
