What HP to replace stock fuel pump?
Old Sep 6, 2007 | 10:14 PM
danf1000's Avatar
Default What HP to replace stock fuel pump?
looking at around 440-480 with the fun button on.
will this pose a problem with the stock fuel pump??
an idea on safe fuel injectors would be appreciated as well! (80% rule)
Old Sep 7, 2007 | 11:10 AM
Nasty N8's Avatar
You will need to replace the stocker it is only good to about 400-430rwhp. 42# injectors will suffice.
Nate
Old Sep 7, 2007 | 10:08 PM
danf1000's Avatar
Thanks, nasty
Anyone agree with the fuel pump rating??
Old Sep 7, 2007 | 10:12 PM
trans am1's Avatar
Nate
ya about 420 is where i was maxed out on fule with the stock pump
Old Sep 9, 2007 | 01:30 AM
danf1000's Avatar
racetronix is selling a kit, sounds like, that retains the stock function, including direct fit and bowl-filling venturi effect, with a walbro pump. i found another kit from full throttle speed that does the same thing, with the Walbro fuel pump, again, for 100 bucks less......
anybody have any insight into this?? what is the appropriate change? is a kit needed or can the existing hardware be moved over to the new pump, perhaps with a sleeve for the smaller diameter walbro??
Old Sep 9, 2007 | 02:01 AM
Websy21's Avatar
Its definelty worth the money to go with the racetronix, you'll regret it if you don't.
