Racetronix instal
Old Sep 8, 2007 | 02:27 PM
stonemonk's Avatar
Default Racetronix instal
Hey guys, im going to be installing the racetronix fuel pump kit this weekend, anybody have any tips or pointers? I will be cutting the floor to make the access hole to make things easier. Is there anything else other then the kit i need or should be aware of?
Old Sep 8, 2007 | 03:50 PM
purdueranger's Avatar
make sure you don't cut too deep. my 2000 had the fuel pump at the back of the tank and we bairly missed the wires. you can see from the thread that I started. I ended up cutting mine to the black sharpie line that I made.
Old Sep 8, 2007 | 04:42 PM
STKN1STGEAR's Avatar
Default 99 camaro
I cut mine just inside the two ribs. Are you going to install an additional feed wire for good voltage?
Al
Old Sep 20, 2007 | 07:46 PM
stonemonk's Avatar
Man, sorry for the delay, i did not end up doin it that weekend got real busy, however im doin it tomorrow, i bought the kit from racetronix w/ the connectors, not sure what your talkn about upgadin wire, i have the ground cable kit from them to.... so the instal is fairly simple but be careful cutin the hole?
Old Sep 21, 2007 | 08:33 AM
mterveen's Avatar
Default trap door
second the comment on not cutting too deep. even tho i was super careful i ended up nicking the wires with my dremmel on the rear bumper side of the cut. the wires were pressed up against the bottom of the trunk so it was virtually impossible to not cut them. had to redue them before reinstall.
Old Sep 21, 2007 | 08:48 AM
Hennytime's Avatar
3rd for no deep, i cut maybe a 1/2" and the way my wires were loomed was i just barely nicked them. go very slow and take your time
Old Sep 22, 2007 | 02:43 PM
stonemonk's Avatar
The install went real good, took about 2hrs w/ alot of slackin off and takin my time. The reason for the install was that fuel pressure was bleeding down very quickly and the car would have trouble starting after it sat. Now pressure holds good and it starts right up. Thanks for the help, cuttin the hole was easy, i cut a U and bent up the floor and then bent it back sealed it and put a latch on it when i was done.
