'94 T/A Fuel Pump Change
Old Oct 11, 2007 | 01:38 AM
kevin-557's Avatar
Default '94 T/A Fuel Pump Change
Okay, I've Finally Got To Change The Fuel Pump. At Quick Glance Underneath the Car, It looks like i have to drop the exhaust at the very least to get the tank down, And even maybe the rear end?. Hopefully, i didn't look hard enough and it's easier than all that. Say it isn't so
Old Oct 11, 2007 | 01:31 PM
Nasty N8's Avatar
Yes need to drop the rear quite a bit and the exhaust to remove the tank.
Nate
Old Oct 11, 2007 | 02:22 PM
kevin-557's Avatar
Cheese and Rice...What Are The Odds? Go Figure, About The Only Thing That's Been Easy On This Car Is Putting Gas In It, Which I've Become An Expert At. Thanks For The Info!!
Old Oct 11, 2007 | 02:47 PM
7901 WS6's Avatar
Be careful with the Filler neck when you drop it out. And the bolts for the Panhad Bar can be a pain..and watch for the Fuels dont kink them. After I did mine, I wish I would a just cut the hole in the trunk.
By Brett Foote | 2026-06-04 05:00:17
