adjustable fuel pressure regulator
Old Oct 22, 2007 | 07:01 AM
Thule's Avatar
Default adjustable fuel pressure regulator
is anyone using them?
and where can i get them?
should it work fine with racetronix w/voltage booster
Old Oct 24, 2007 | 04:59 PM
Chris99WS6PWTMET's Avatar
Aeromotive P/N 13105. Works well.
Old Oct 24, 2007 | 06:21 PM
Thule's Avatar
where can i get it?
Old Oct 26, 2007 | 10:03 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I got my aeromotive adj. FPR from jegs. Summit has them, and I am pretty sure you can get one from Nasty N8 as well. Just be sure to remove your stock FPR in the tank. Also you will need to run a return line or use your EVAP as a return or use your stock feed as a return and run a new feed line... Lots of options out there. If you have plans for FI be sure to get one that has a 1:1 rise ratio.
Old Oct 27, 2007 | 11:59 AM
code4's Avatar
You'll have to get some kind of fuel pressure guage as well so you can set the FPR at 58 PSI or whatever pressure you're going to run.
Old Oct 27, 2007 | 10:15 PM
ChevyChad's Avatar
True. Most adj FPR's have a 1/8"NPT port built in for gauges or sending units...
