Fuel pump power wire in cab
Old Oct 23, 2007 | 10:15 PM
andyws6's Avatar
Default Fuel pump power wire in cab
I have searched for this on the site but can not find a definitive answer. I am wiring a dual relay to my fuel pump. I have mounted the relay in the cab on the drivers side above where the hood latch pull cord is (didn't know what else to call it). I am thinking that it is the gray wire that is in the bundle of wires that run from under the dash on the drivers side, down under the carpet and on the outside of the seat to the back. Can anyone confirm or correct me? I just want to make sure I tap into the right wire to trigger the relays. Pictures would help greatly. I will try to post some if no one else does. Thanks in advance to all that contribute.
