What will cause fuel pressure to drop?
Old Oct 29, 2007 | 01:10 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Question What will cause fuel pressure to drop?
Is that indicative of insufficient pump only, or could the line size cause that? Right now I'm running the stock 3/8" feed line (-6 equivalent) and two 255 in-tank walbros and my pressure is dropping in the upper RPM's. Do I need bigger feed line, or bigger pump?
Old Oct 29, 2007 | 09:43 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Where is your regulator mounted? What brand is it? Is it a double pump kit that I built?
Old Oct 29, 2007 | 10:53 PM
ChevyChad's Avatar
I think I found my problem... There was a loose connection on the boost activation switch, so I don't think the second pump was coming on.
But my regulator is mounted after the rails, and no, it is not a kit that you built. I built the kit.
