Fuel Pump Stays Running with key "ON"...??
Old Oct 29, 2007 | 07:24 PM
The LT1 That Could's Avatar
Default Fuel Pump Stays Running with key "ON"...??
pump used to prime, then shut off....now with key "on" in acc, pump will continue to whine..... relay, or pump going bad??
Old Oct 30, 2007 | 10:10 AM
t t t
Old Oct 30, 2007 | 10:47 AM
Nasty N8's Avatar
could be a stuck relay but could be wiring issue or computer...alot. Have to follow the signal it it is getting triggered to keep going it is something else if the trigger wire on the relay gets signal for 2-3 sec. but the pump continues to get power it may be a stuck relay.
Nate
Old Oct 30, 2007 | 10:07 PM
locodave46's Avatar
Hi, If the internal relay contacs welded when they touch. It will stay on. Get another relay. Other thought. The oil pressure sensor has an internal contac in it. Get oil pressure, bypasses the relay. Makes the fuel pump come on. Unplug it to see if thats the culprit. Dave
Old Oct 31, 2007 | 12:24 PM
RE AND CHERYL's Avatar
Most likely the oil press switch is stuck. Pull the pul and see what happens. With the oil press switch unplugged the pump should only prime. If you went to start the car it should run for 3-4 sec and die.
Re'
Old Oct 31, 2007 | 06:37 PM
were there some typos, or should I just be this confused, lol....
so basically, check oil pressure switch, if not that, replace fuel pump relay
thanks for the tips everyone, appreciate it
