injector fitment???
Old Nov 8, 2007 | 12:19 PM
blackbyrd's Avatar
Default injector fitment???
should the injecor fit tight in the in the bung or can it have wiggle room,
i made a post previously about using the l92 o rings on ls1 injectors the seal seems ok it fits better than it did with the ls1 rings but still wiggles so my questions is do i need to look into another set of o rings or should this be fine??
i know with the ls1 intake from memory it seems the fitment was a lot tighter but then again it was designed for ls1 injector and the l76 injector is bigger is it not???
i know k tech makes a kit but all i need is the o rings not the bolts
Old Nov 8, 2007 | 12:45 PM
Ericbigmac83's Avatar
wiggle room means room for the fuel to come spraying back out. so i guess it depends how much "wiggle room" youre talking. you'll know for sure once you fire it up, lol
Old Nov 8, 2007 | 02:00 PM
blackbyrd's Avatar
well once the injector is in the rail its does wiggle but i am concerned the seal my not be tight enough but there also isnt anything holding the rail on at this point everything is just setting in place
Old Nov 8, 2007 | 04:37 PM
might be ok, cant you bolt it in and see?
Old Nov 8, 2007 | 05:04 PM
blackbyrd's Avatar
wont know till i fire it up and the engine is out of the car and i wont be able to pressure check the system for a while im trying to get a harness debocle organized
Old Nov 10, 2007 | 12:18 AM
chewy99ws6's Avatar
I have 60#'s and they wiggle back and forth, car runs just fine and haven't had any leak issues, so I would say you should be fine.
Old Nov 10, 2007 | 02:09 AM
blackbyrd's Avatar
sweet thats what i wanted to know
