Fuel Problem I Think!!!!!!!!!!help
Old Nov 15, 2007 | 11:38 PM
1sicss's Avatar
Default Fuel Problem I Think!!!!!!!!!!help
I have a 1997 Camaro SS it has CC503 p&p heads and all the supporting mods even tune from PCMforless/trifecta perf. Stock fuel pump, anyways I went to the track on DR's all suspension done and my 1st run was 13.7@101mph but then when I went back to the pits my car was struggling to stay on, so much so that I had to keep my foot on the throttle to keep it on when moving very slowing or it would shut off. It run fine after being in park and keeping the RPM's at around 1300rpms for while. Ran it again and ran a 14.1@98mph went back to the pits and it would shut off when braking to a standstill in drive, and once again gave it a little throttle for a while and would run fine after a couple of minutes. So I went home and measured my FP and it was at around 45psi @ idle. What could it be??????????
Old Nov 16, 2007 | 07:12 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
With 45psi is should idle. I would not suspect the pump at this point.
If there was low pressure, I would suspect a pump, line or regulator... but it seems OK.
At first, I would look for a loose hose on the air intake that affects the maf reading. Maybe the throttle body connection.
Let me know what you find.
