hooking up after market regulator, disconection old.
Old Jun 23, 2003 | 05:54 AM
smokinHawk's Avatar
Default hooking up after market regulator, disconection old.
got my tank out last week, and im tryin to figure out what exactly is the stock regulator.
how do you disconnet it and what is all needed to route the new system?
this is a 99 plastic tank and system.
thanks.
Old Jun 23, 2003 | 02:27 PM
smokinHawk's Avatar
Default Re: hooking up after market regulator, disconection old.
UP
Old Jun 23, 2003 | 07:17 PM
Chris99WS6PWTMET's Avatar
The tube on the top marked "R" goes into the regulator. Remove the locking clip and pull out the stock reg (its a golden colored button with a small vent tube on it), but be careful as there is a mesh screen and an o-ring behind it. After I pulled mine I cut and flared the line going to the T-block under the car and ran my new return from the engine to the newly flared line. I couldnt find a plug for the stock T-block, so I cut and flared both of those lines and installed a -6 union.
(I'll email a few pics. Sorry I dont have a pic of the intank reg.)
Old Jun 23, 2003 | 07:20 PM
Scratch the emailed pics, as you have no posted email addy. Sorry.
Old Jun 24, 2003 | 05:11 AM
smokinHawk's Avatar
thanks, my email is
jd_harder@yahoo.com
Old Jun 25, 2003 | 03:22 PM
smokinHawk's Avatar
anyone else got any info on removing the stock regulator?
Old Jun 25, 2003 | 07:35 PM
You still havent got it off yet? Is the fuel module out of the car? If so:
1. hold it in front of you
2. Find plastic port w/ "R" on it
3. follow down to underside of module top
4. it runs to the thing that resembles your pulse damper on fuel rail.
5. remove the metal clip
6. pull out regulator
7. watch for screen and o-ring
Old Jun 26, 2003 | 02:12 PM
smokinHawk's Avatar
is it on the out side of the tank or inside the pump assembly. I have it all out
im not sure what those black boxes that are attached to the tank.
or some bronze thing inside the fuel assembly.
maybe i can get pics.
