Meth install...Need help
Old Nov 30, 2007 | 04:02 PM
kidcamaro98's Avatar
Default Meth install...Need help
Ok so i have the stage 2 snow performace MAF kit. I have everything hooked up. Everything is hooked up right but for same damn reason, the pump wont go on. I tested the pump to make sure that wasnt bad, and the ground was right by hooking it up to my battery for a quick second and it worked like a champ. Now, I dont know if any of you are familier with the snow kits but Theirs 2 boxes that hook up. Ones a variable MAF timing box, and the other is a VC-MAF. The Green wire (position 4) hooks up to the pump...Once thats hooked up, when you decrease the start up voltage on the VC-MAF controller, the pump should activate. Now, nothing happens. For some reason, that wire is not getting any power...can anyone help me?
heres the kit I have...http://www.snowperformance.net/produ...ion_pdf-57.pdf
