Need help with fuel system 1000hp please!! Long post
Old Dec 13, 2007 | 06:28 PM
Schurters LT1's Avatar
Default Need help with fuel system 1000hp please!! Long post
Well i am trying to fig out what i need and i just don't under stand it all these fittings/clamps .....
I have the twin intank setup..
i want to come off the sending unit with:::Fitting,AN Quick Connect,Straight,-8 AN Female Threads to 3/8 in. Inverted Flare,
http://store.summitracing.com/partde...5&autoview=sku
what fitting will go into this so i can run -8 to the fuel filter:: Fuel Filter, Inline Mount, Aluminum, 100 Microns, Red, -10 AN Female Inlet/Outlet, Each
( i will need fittings to go from -8 to -10 on both ends of the fuel filter )
from the fuel filter -8 line to the front
NOW!!!!
do i run a Y and feed each rail?????
OR
do feed one rail then cross over to the other rail then to the reg???
https://ls1tech.com/forums/showthrea...ht=fuel+system
What (boost FPR do i need or should i get )
what do i need to go into the Y block and come out
then over to the rails and out .....
what about this post
thanks
