Yet another stock fuel pump question
Old Dec 16, 2007 | 02:03 AM
chpmnsws6's Avatar
Default Yet another stock fuel pump question
Right now I have 03 Cobra injectors in my 99, which Ford rates at 39 pounds at 39psi. Have anyone tested the limits of the stock pump? I have a h/c car that will be in the 420hp range (as a goal) and a 150 shot. As you know, fuel pressure drops from 58psi down to ... when you go WOT and start juicing, so my question is, how low a pressure have you ever seen? If I dropped fuel pressure down to 39psi, would it then supply enough flow? I'm trying to get around having to install a fuel pump in the Vette, as the only kit I've seen costs nearly 300 dollars.
Old Jan 15, 2008 | 10:31 AM
chpmnsws6's Avatar
ttt......
Old Jan 16, 2008 | 05:15 AM
SSMOKIN_Y2KSS's Avatar
your gonna need a bigger pump for sure im surprised that those injectors havnt dried out the pump already.hows your air fuel doing?
Old Jan 17, 2008 | 12:12 PM
RE AND CHERYL's Avatar
If your gonna use the juice, your gonna need a pump. All the calculations the PCM uses to inject fuel are based on the fuel pressure being at or near 58 PSI. If the stock pump can't keep up and the pressure drops off while on the juice then you will obviously run lean.
LEAN + NITROUS = A BAD DAY FOR YOU
Re'
