Help me identify an injector
Old Dec 20, 2007 | 09:27 PM
cabel1's Avatar
Default Help me identify an injector
I can get a set of injectors fairly reasonable but am having trouble identifying them.
The #'s on them are F7PU-A4A and 9F593 and they are black top.
http://www.witchhunter.com/flowdatapix/ff7pu-a4a.jpg
That is a link I found. I was told they were 36 lb ford injectors but I'm not certain.
Old Dec 24, 2007 | 11:14 AM
Goldfinger911's Avatar
Those are in fact 36lb Ford injectors.
Old Dec 26, 2007 | 08:15 PM
cabel1's Avatar
are they any good for a performance build?500hp or so?
Old Dec 26, 2007 | 11:37 PM
With the stock LSx fuel pressure of 58lbs, they should max out around 41-42lbs of fuel. This should make for a 500whp build. My car made 493whp with SVO 30lb injectors.
Use this page to give you a rough estimate of fuel needs.
http://www.rceng.com/technical.aspx#...tor_Worksheet_
Remember, this is assuming the car is tuned properly.
Old Dec 27, 2007 | 09:03 PM
cabel1's Avatar
Thanks for the info!
