boost ref fuel system
Old Dec 23, 2007 | 05:56 AM
forcd ind's Avatar
Default boost ref fuel system
i have run several carb'ed prochargers, and always boost ref'ed the reg as required-i will be running FI on the new setup, and was wondering how you are boost ref. the FI setups-if your running an external reg. then i guess you can run a boost line from the intake area to the reg if it has a provision for it-what about a stock type car, where the reg is built into the pump? is the int.
high pres enough to feed over the boost? as the boost would go up, w/o boost ref., seems the injector flow would be fighting against the boost-did a search, didnt really find an answer-thanks
Old Dec 23, 2007 | 06:51 AM
EPP's Avatar
EPP
If we are pushing past 600 rwhp we swap out the complete fuel system to one with larger fuel lines with a return line, and we use a boost referenced regulator. Check out my car here where we ran a whole new fuel system. I have quite a few pictures of it.
http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old Dec 23, 2007 | 07:57 PM
vette#3's Avatar
Bob I must say u guys have put alot of time in this car & it really is a nice ride,I really like how u stepped by stepped the process ,to give people a break down on what really goes on ,i would drive it
Old Dec 23, 2007 | 11:39 PM
mikep2002's Avatar
What car are you looking at doing this fueling upgrade on.
