97-98 vette fuel rail users,quick question?
Alex
You can use part number(summit) RUS-640850 to adapt the 3/8" gm quick disconnect to -6AN and use some sort of an fitting and hose, or you could use a 3/8" compression fitting on the rail to adapt it to -6AN.
Are you talking about the return connector?? It's the same but slightly smaller. I've got one left over from my LT1 set-up.
Are you using the evap line from the tank as a return. I really hope you replumbed the lines to the tank. That line goes to the evap cannister and NOT the fuel tank.
Re'
