Injectors O rings question
Old Jan 24, 2008 | 11:38 AM
Mike Cordero's Avatar
Default Injectors O rings question
Where can I get the O rings for a set of Motron 60# injectors?
Old Jan 24, 2008 | 01:08 PM
Nasty N8's Avatar
Check your parts store.
Nate
Old Jan 25, 2008 | 10:12 AM
koolaid_kid's Avatar
Perhaps the question might have been worded: Do the Motron #60 lb. injectors use stock or stock-compatible orings, or are they different from stock?
Old Jan 25, 2008 | 12:56 PM
Default O rings
I bought those injectors used, and when received didn't have O rings on any of them, so I need to buy the O rings for the 8 injectors. Thanks.
Old Jan 25, 2008 | 08:57 PM
I have not used the Motrons. However, I have used 2 different sets of aftermarket injectors, and they both used the same orings as stock.
I have purchased said orings from 2 different parts stores, and neither fit as well as a set from the dealer. They were too thin and did not seal as well as the thicker stock rings that I bought from the dealer. Cost - ~$20.
Hope that helps.
