GTO fuel pump ?
Old Jan 29, 2008 | 04:27 PM
SSsuperdave's Avatar
Default GTO fuel pump ?
What is the H.P. limit for an 06 GTO fuel system. Is the fuel pump the weak link or are the injectors the limiting factor? Does anyone have any specs on the stock fuel system?
Old Jan 29, 2008 | 06:08 PM
Jake@EPP's Avatar
We find you can usually get away with heads and cam on a ls2 gto. Any more its upgrade injectors and a 255lph pump. Any more then 550rwhp and i would do a sump tank or a 044 intank.
Old Jan 29, 2008 | 06:16 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
To further answer the question, the injectors limit flow way before you run out of pump. I have used the stock pump on my '04 to slightly over 500rwhp, but this was using 60# injectors and tuning around the pressure drop (not recommended).
