Questions about drilled out injectors. Help please.
Thanks
Andy
Andy
If you are spending enough money to build a blown big block, it would be rather foolish to buy anything of either cheap or unknown quality.
1 lean cylinder generally means pulling & fixing the motor. Repairs are much more expensive than the potential savings of cheap injectors.
FYI 160# injectors will typically support well over 2000hp on gasoline, meaning they are likely way too large for all but the most extreme engines.
