running lean on nos Help?
Old Feb 2, 2008 | 12:14 AM
rainwater_racing's Avatar
Default running lean on nos Help?
2001 f body built 347 w h/c 36lb injectors running racetronixs plug and play pump on 250 shot fuel pressure dropping on the hit.need quick solution!
Old Feb 2, 2008 | 09:53 AM
00cls1camaross's Avatar
does the fuel pressure come back up after the nitrous hits?
Old Feb 3, 2008 | 01:22 PM
Frost's Avatar
No quick solution; you don't have near enough pump. A shot like that needs it's own fuel system up front seperate from the engine. Other option is a much larger pump in the back.
Old Feb 3, 2008 | 01:34 PM
edcmat-l1's Avatar
Yep. And even with a bigger pump, if you're not running a second fuel system, you will still get a drop in pressure when the solenoid opens. It may come back up, but it will still drop.
Old Feb 5, 2008 | 09:31 PM
seperate fuel system? talking about fuel cell and pump to fuel solenoids, then running engine off factory fuel system?
