need an injector calculator and help
Old Jul 10, 2003 | 08:15 PM
rich's Avatar
Default need an injector calculator and help
I have a friend with a 95 lt1 convertable 383 cu in AFR 190 cc heads vortec super charger(12 psi) Flp headers dual fuel pumps. The car made 525rwhp on FLP's dyno. The car has 60lb injectors (too big in my opinion) 60psi of fuel pressure. The car is pig fat at idle. I think a set of 38lb svo injectors with maybe 50 psi fuel pressure with a boost a pump system would help out if not solve the problem. Then you could tune the cars ecm. Any info will help thanks Rich
Old Jul 10, 2003 | 09:07 PM
Gofast's Avatar
Default Re: need an injector calculator and help
Try this link for fuel injector sizing: www.rceng.com/technical.htm
