Strange Idle and Fuel Millage???
Old Feb 5, 2008 | 07:28 PM
Shepp1691's Avatar
Default Strange Idle and Fuel Millage???
I have an 02 Z28 with 30k miles on it, lately it has been idling anywhere between 1000-3000 rpms and getting about 13 mpg. It is a six speed so the millage is way off. It does have an air box, flowmaster, and 4:11 gears. I just replaced the O2 sensors and it has changed nothing. I dont know much history on the car so it could have a tune in it or anything, but the dealer wants $80 to flash the ECM. I dont want to do that unless I am pretty sure it is the problem. Also no check engine codes, could be the MAF sensor. Any advice would be appreciated.
Thanks,
Dave
Old Feb 5, 2008 | 08:28 PM
167camaro's Avatar
Have you checked for a vaccum leak? That's what it sounds like to me with the high eratic idle.
Old Feb 6, 2008 | 10:37 PM
Shepp1691's Avatar
Checked the vacum leak with no success, getting the ecm re programmed by gm on friday. I unplugged all the emmission controls and never had a change idle or a code pop up, so something tells me the car has been tuned.
Old Feb 8, 2008 | 01:30 PM
Shepp1691's Avatar
$45 to get the pcm flashed, ill let you know how it turns out, going today
Old Feb 8, 2008 | 09:50 PM
Shepp1691's Avatar
reprogrammed the ecm and it runs like new... couldnt be happier
