Another Fuel pressure regulator ?
Old Feb 7, 2008 | 06:32 AM
blacksi's Avatar
Default Another Fuel pressure regulator ?
I'm looking to get an boost adj fpr for my t76 347 LS1. I plan on running dual walboros. I am going to have a 8AN feed to the rails with stock return 6an'ish. I wanted to feed one rail, cross over and 1 line out to the FPR. Does the line out to the FPR need to be 8AN also or is 6 fine?
Old Feb 7, 2008 | 09:00 AM
code4's Avatar
Either way would work, you should ask this in the fueling section.
Old Feb 7, 2008 | 09:41 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Either, but most FPRs are -6. At least the one I use is anyways. I'm running the same way- dual walbros and crossover. LMK if you need the p/n of the regulator I used because it has just the single port like what you will need.
Old Feb 7, 2008 | 12:53 PM
blacksi's Avatar
Yeah if you could. If you get a dual I assume you would just cap one inlet off?
Old Feb 7, 2008 | 01:47 PM
ChevyChad's Avatar
I went with the aeromotive 13155 FPR. It is the same as the 13105 FPR, just shiney
