Need help with hoses and fittings
Old Feb 7, 2008 | 06:08 PM
95GreenZ28's Avatar
Question Need help with hoses and fittings
Ok I have a 99 vette filter regulator in the stock filter location on my 95 ls1 car. I want to run braided line from the filter to the fuel rail. I need an adapter from either 3/8 quick connect or the 3/8 female end of the T. Then I need enough line to run to the engine bay and connect it up to my fuel rails. Anyone know exactly what adapters I would need and the best place to get them and the braided 6an line? Thanks in advance for any help!
josh
Old Feb 8, 2008 | 12:43 PM
Nasty N8's Avatar
I keep this stuff in stock. Give me a call I will set you up with what you need.
Nate
Old Feb 8, 2008 | 01:15 PM
DMH Fabrication's Avatar
I would give Nate a call and he can get you straight and save you alot of time that you would spend trying to guess what you need. He is a great guy to work with from my past experiences.
Old Feb 8, 2008 | 01:19 PM
95GreenZ28's Avatar
Thakns guys! I may have gotten it figured out. I am having a guy braze my hard lines together for now. I will def give you a call Nate when I am ready for the braided line. Actually what I need if I were to do it is 9ft of braided line with a 3/8 quick connect on one end and a line to connect it to the fuel rail on the other end. How much would that run me? Thanks man!
